Removing a seized injector
Found that number 4 injector on my 06 reg vivaro is fooked & as on all common rail diesels its seized in the head!!
I removed injectors 1,2 & 3 no problem but number 4 is solid!
I've undone the clamp & soaked it in wd40 with the intention of using it until it decides to pop out itself but wondered if theres anything else I can use to help free it up?
I've heard of coke, oven cleaner etc but there's surely has to be something on the market that's stronger & more effective in situations like this??
I spoke to my mechanic & various engineers who said if it runs & drives ok, soak it up, undo the clamp & use it til it pops out!
My mate said he drove he's for a week then all of a sudden on his way home it came out!! Had the new one to hand which he fitted & off he went...... Hope I'm that lucky but not gonna hold my breath!
passionford pro
get grafitti x from wurth and keep soaking it around the injector...it dissolves the carbon eventually . if you have access to a hot power washer you can most of the time dislodge the carbon. its been leaking slightly at the seal and just builds up. make sure you get the copper washer out at the seat if there is one and use a new one with new injector.
if that fails a lot of diesel places now have hydraulic pullers just for this job. Good luck.
The best thing for these believe it or not is cillit bang. I work for Vauxhall and the technical team recommend that to us. If no joy, all Vauxhall dealers now have a specially developed puller to remove them.
Matt
Matt
Seen alot of lads unscrew the top off the injector then have a heavy duty slide hammer with a UJ on the end screw on bang on ET VIOLA!!!
but yeah cillit bang in the meantime
Didnt think it was a build up of soot? thought it was water leaking onto injector, causing the two different metals to fuse together
Either way a nightmare to sort
Renault themselves actually sell a tool specially for removing injectors. Downside is that it costs about £800. It does however work.
Your local dealer may rent you the tool.
Problem is they want £300 to come down as the nearest on eBay is Norfolk & I'm south London!
Ive just spoken to a specialist in knockholt who said he can do it Monday for £175 but really needed it done sooner.
Spoke to a few people advertising on eBay & the prices ranged from £364 up to £450!!
Personally I think that's a rip off when I could pull the head off myself & get to it from the other side.... Would cost me half that!
Best get the spanners warned up!
If it's properly seized, then the only thing that will remove it is the correct tool, or destructive means.
The correct tool will be cheaper.
You could buy the tool from Renault then rent it out yourself lol
Get them to order it up !!
Even a basic slide hammer tool will be more than that, or around that. But the proper tool bolts to the head and uses a screw puller to remove the injector. And even then it can take a fair bit of effort.
Two things can happen. Either the injector comes out, or it rips the injector in half.
Anybody for a brew?
Sorry not read all this thread but i used a slide hammer on a Lexus IS diesel, took some doing well a full day but did it with no damage to anything other than the injector.
Nightmare to get out these injectors we have the special tools for them at work been a vaux dealer and have broken 3 of them in the past, we normally now find it cheaper and easier to whip the head off send it to engineers down the road.done quite a few this way now and found it much better.
They dont seize in the expand in to the head. The only way I have had to get these out is to have the head machined. You may need to be prepared to buy a new head.
The same engine is used in other vehicles, and they dont suffer anywhere near as badly. It's just bad design of the vehicle they are installed in
but they are French, so you wouldnt expect anything other than bad design !
