Ford XR Range This forum is for discussion of all things pertaining to the Ford XR Range of cars.
XR3i runnig problem / rev's
Old 14-08-2011, 09:59 PM
robxr3icab
robxr3icab's Avatar
Default XR3i runnig problem / rev's
Hi All,
Got a little problem with my mk4 cab, the engine starts first turn of the key, ticks over nice, but soon as you give it any rev's it sounds like a bag of s*it, It back fires in air chamber and coughs spit's and farts, stop reving and ticks over nicely. so any idea's (could it be a sticking valve or tappet or just needs a good tune and timing setup)????
Cheers for any help
Old 16-08-2011, 10:01 AM
robxr3icab
robxr3icab's Avatar
Any idea's anyone ???????????????????????? PLeeeeeeeeeeeeeeeeeaaaaaaaaaaaassssssssssssssseeee eeeeeeeeeee
Old 28-10-2011, 01:16 PM
stevo123
stevo123's Avatar
Check/clean plugs and leads. Inspect rotor arm and dizzy cap. Check operation of the fuel metering head flap-might be sticking. Compression test would show up a sticky valve. make sure the cold start injector is not constantly on (unplug the plug on thew valve - it is situated on the rhs of the plenum chamber and has a red fuel line running to it.
Usually is something simple with these but may also be fuel pressure/control pressure related and down to the warm up regulator (WUR for short) if you google it and have a read up on kjet fuel injection you should be able to diagnose most issues.
Bets of luck with it mate
Old 16-02-2012, 02:42 PM
JasonXR2Racer
JasonXR2Racer's Avatar
check all your air pipes are not split or loose
could be a timimg issue
is it ok once its warmed up?
morg65
Escort MK 5 / MK 6
23-09-2015 08:57 PM
morg65
Escort MK 5 / MK 6
23-09-2015 03:19 PM
Shaunc
Escort Range
23-09-2015 06:00 AM
phs84
15-09-2015 05:30 PM
morg65
Escort MK 5 / MK 6
17
11-09-2015 08:40 PM
Quick Reply: XR3i runnig problem / rev's
