rebuilt engine running mega rich
Old 26-08-2016, 09:02 PM
MARKYMARKONE
MARKYMARKONE's Avatar
Default rebuilt engine running mega rich
Hi
Ive just started my freshly rebuilt engine in my 2wd cosworth, which has all new genuine sensors, new loom running l8 ecu, sieman 83lb injectors , 044 fuel pump and loom etc.
Its running mega rich pumping out black smoke.
Has anyone got any ideas?
Should the 044 fuel pump prime every time engine is started?
Mark
Old 26-08-2016, 10:15 PM
Mad_Mat
New Owner
Mad_Mat's Avatar
Check fuel pressure.
Old 27-08-2016, 05:45 AM
Gavinbat
Gavinbat's Avatar
Hi,
Check there's no fuel coming out of the vacuum pipe on the pressure regulator.
Also check the wiring between the ecu and the coolant temp sensor.
Have you got the right TPS wired up correctly for the L8?
Cheers,
Gavin
Old 27-08-2016, 06:53 AM
carl n 1977
carl n 1977's Avatar
Map sensor ?
Old 27-08-2016, 06:12 PM
costina
Live long and prosper!!
costina's Avatar
We could all give you something to look at and you could be lucky.
My advise is take it to a cossie specialist before you bore wash your new engine build......
Old 27-08-2016, 06:44 PM
Caddyshack
Caddyshack's Avatar
I agree, give it to one of the old and the bold and get it properly sorted.'If you add a location to your profile we can recommend a few. My recommendation is MA Developments, Mark Shead
Old 27-08-2016, 08:17 PM
jamie956
jamie956's Avatar
Map sensor, mine was over fueling so much it wouldn't start it was a brand new 3 bar out of the box as well.
Old 01-09-2016, 07:39 PM
MARKYMARKONE
Hi guys thanks for replys.
Ive been looking into this issue, went to start the car tonight and there is no power to fuel pump from relay.
Ive tried new relay no volts
Ive connected pump direct to battery ok.
Ive checked for feed behind ecu no volts.
I disconected the ecu and bridged out pins 1 + 10 and 19 +28 switched on ign and pump primes.
Reconnect ecu pump wont prime.
Disconted injectors and crank sensor, reconnected ecu pump now primes. Connect crank sensor and pump wont prime again
Has anyone got any ideas on what to do next
Mark
cos elle
33
31-01-2018 05:18 PM
siscossie
02-04-2016 09:02 AM
MARKYMARKONE
19-03-2016 01:34 PM
Alan G
59
29-02-2016 06:22 PM
JohnnyR6
Other Marques
10-11-2003 09:33 PM
Quick Reply: rebuilt engine running mega rich
