2wd saph cosworth crank seals leaking
Hi all I've hit a bit of a dead end with this rebuild.
I've recently had the engine rebuilt and after 220 miles I noticed the rear main began to leak. Took it to a mate who has a garage - replaced the rear main and now after 500 miles I have the rear main leaking & the front crank seal too.
It only seams to leak whilst driving under load - engine idle it doesn't look to be leaking.
After speaking to a few people been told to check the oil pressure and crank case breather system for blockages. Before looking at seals anymore
Completely standard cosworth had a full engine rebuild with the following:
205 block bored and fitted - Mahle 0.5 over sized Pistons
Mahle std bearings / shells
Polished crank journals
Cylinder head valve guides replaced along with stem seals
Head minor skim
High pressure oil pump
Group A head gasket
Full gasket set -cometic - victor reinz oil seals
Reffited original T3 turbo as it ran fine before with no oil leaks
So today I took off every aspect of the breathing system but it's all clear - blows through fine. Ordered a pressure gauge and adaptor for the block.
Anything else I may have missed ?
Head minor skim
Group A head gasket
The plan was to run it in then go for t34 & greens
Aiming for 350 bhp.
Was advised to fit the better pump for when I decide to upgrade
Aiming for 350 bhp.
When I fitted the seals I used a smear of sealant around the outside of the seal. It's defiantly coming from the centre of the seals. When gearbox was removed it was clear to see where it has been running from. Sump was dry along the back. my next move will be to rig up a oil pressure guage and do a compression test.
When engine is at idle speed the seals do not leak but after a drive it's clear to see where oil has came out and splash down the exhaust and sump
Yep - I followed the ford Sierra workshop manual and put sealant on the rear cap joins and along the block where the cap meets the block on the side.
When I took off the flywheel the block was dry.
I'm going to do oil pressure checks and compression checks before looking at the seals anymore.
Hi - did you get tot he bottom of this please? I found this thread as I'm looking to establish if the breather system is blocked on my 2wd. The only item I haven;t checked was the tank type piece that drops into the block. Do you know if this is a culprit for blocking up before I start looking to remove it and inspect it please?
Thank you
Thank you
madfortaryb
15
01-03-2016 06:33 PM
-J-
14
08-10-2003 09:49 AM
