antifreeze
Old 11-08-2016, 10:14 PM
MARKYMARKONE
MARKYMARKONE's Avatar
Default antifreeze
Hi
What colour antifreeze coolant is used in a cosworth yb?
Mark
Old 11-08-2016, 11:00 PM
bigdel
bigdel's Avatar
Went to Ford and they gave me the recommended stuff. Was bright yellow
Hezz (12-08-2016)
Old 12-08-2016, 05:52 AM
RichieST
RichieST's Avatar
You can use whatever you like, just don't go mixing different colours.
Old 12-08-2016, 06:08 AM
costina
Live long and prosper!!
costina's Avatar
Back in the day it was blue.
As said don't mix.
You can get a coolant called prestone which is yellow and turns green if you have headgasket issues
Old 13-08-2016, 09:10 AM
Mondi-DZK
Mondi-DZK's Avatar
As said don't mix.
Don't start... i'm just over it...
On topic, i have the yellow stuff now and it's still yellow
Old 13-08-2016, 10:22 AM
martysmartie
martysmartie's Avatar
Blue is IAT, the newer stuff is OAT, which causes damage to older engines.
The benefit is, the latter has a longer life.
Martin
Old 13-08-2016, 10:26 AM
costina
costina's Avatar
Martin
100% correct.
Old 13-08-2016, 11:10 AM
RichieST
RichieST's Avatar
How will the newer stuff damage an older engine?
Old 13-08-2016, 12:56 PM
martysmartie
It can attack gaskets, solder used in older radiators etc.
Martin
Old 13-08-2016, 02:33 PM
costina
costina's Avatar
Martin
We have these issues sometimes at work with the vintage and 50's cars.
Also iat and oat mixed can cause it congeal and block water ways.
Old 13-08-2016, 03:52 PM
funkyboozer
funkyboozer's Avatar
I use that Evans waterless coolant. Seem to be good and haven't got to worry about mixtures
Old 20-08-2016, 12:24 PM
MARKYMARKONE
Cheers guys, blue coolant it is then
Mark
Old 21-08-2016, 11:07 AM
Turbosystems
Super Moderator
Turbosystems's Avatar
As said don't mix.
It was pink from the factory
Old 21-08-2016, 12:29 PM
costina
costina's Avatar
Really!! i learn something new everyday cheers Tony.
What spec would that be?
Paul
Old 21-08-2016, 02:04 PM
Turbosystems
Super Moderator
Paul
Gay spec
Old 21-08-2016, 04:32 PM
costina
costina's Avatar
Gay spec
So your in one of those moods
Old 27-08-2016, 08:47 AM
Gavinbat
Gavinbat's Avatar
Hi,
Ford Super plus was the pink stuff factory fitted to all Ford's of the era.
Cheers,
Gavin
Old 27-08-2016, 09:44 PM
bigdel
bigdel's Avatar
The ford super plus i put in mine was luminous yellow when it went in, but has turned pink now water has been added.
Old 28-08-2016, 10:47 AM
1374lee
1374lee's Avatar
So what's the alternative these days as you cannot get the old type ford coolant anymore.
I'm gonna be looking into this when my engine bay resto is gonna get underway soon.
What about Blue col? Any other alternative, would prefer to stick with old type coolant for the YB.
Thanks. Lee.
Old 28-08-2016, 10:53 AM
costina
costina's Avatar
I use oat in mine. Its like what oil you use debate.......
Blue col with distilled water will be as good as most imo.
Old 28-08-2016, 03:24 PM
Gavinbat
Gavinbat's Avatar
Hi,
It came from the factory with pink stuff in it so I got pink stuff from Euro and put that in.
As far as I know blue lasts 2 years and pink 5.
Cheers,
Gavin
Old 31-08-2016, 07:04 PM
martysmartie
Thanks. Lee.
Most (as do I) use OAT, as Tony said it was not IAT originally.
Martin
Old 31-08-2016, 07:10 PM
bigdel
bigdel's Avatar
As I said earlier. I gave Ford the antifreeze spec from my manual for the Cosworth, and they gave me the correct stuff. It goes in almost luminous yellow, but when you add the water it goes pink.
Old 31-08-2016, 07:12 PM
martysmartie
It's all the same really, barring what type it is.
Martin
Old 31-08-2016, 07:13 PM
Mondi-DZK
Mondi-DZK's Avatar
Got the pink stuff in the new Fiesta to. Original Ford to. I think in the Mondeo it was pink to...someday long ago. Never really care.
cos elle
20
05-09-2016 11:52 AM
cavyturbo
03-06-2016 08:33 PM
900ss
26-05-2016 06:54 PM
carterhall14@hotmail.com
18-05-2016 09:28 PM
Quick Reply: antifreeze
