testing
Old 09-08-2016, 01:34 PM
jimhc
big jc
jimhc's Avatar
Default testing
I'm having a problem with over fueling badly. I have changed the wts with 2 new sensors still no difference. I'm wondering how do you check to see if a 3 bar map sensor is working properly?
Old 09-08-2016, 05:47 PM
cossie2
cossie2's Avatar
are you sure that the eprom is written for 3 bar map sensor..if so try again replacing the blue water temp sensor..
MAP SENSOR CHECK: Check for DC voltage of approx 1.8 to 2.5V between pins 11 and 15 with ign on..
Old 09-08-2016, 05:57 PM
costina
Live long and prosper!!
costina's Avatar
Fuel pressure check also check fpr is not leaking into plenum.
Dr. Ickxs
13-06-2016 03:31 PM
BAI7200
09-06-2016 08:11 PM
Fudgey
18
24-05-2016 08:42 PM
James d
23-05-2016 09:41 PM
ByronG
17-05-2016 01:42 PM
Quick Reply: testing
