Burton Power Wheel Bearing
Old 04-06-2016, 12:24 PM
uk-doctor
uk-doctor's Avatar
Default Burton Power Wheel Bearing
Has anyone used any wheel bearings from burton power??
Ive bought both front and rear wheel bearings from burton power for my 4x4 saph cosworth, about to fit them but have noticed they are a little bit loose around the hub asif the hubs have slightly worn, so ive opted for loctire 620 to conpensate for them not being able to be pressed in. But now after speaking to burton power to see who manufacturers there wheel bearings theyve told me they are unbranded and are made in CHINA!!!! alarm bells! so now im thinking are my hubs actually fine and these cheap shit burton power wheel bearings at fault???
Also seen these on ebay anyone used them?? Look at this on eBay:
https://www.ebay.co.uk/itm/311624958832
Wheel Hub FEBI BILSTEIN Ford Escort RS Cosworth 4x4
Any replys will be really aprciated as im in the process if peicing the car back together and this whole wheel bearing nightmare is slowing me down!
Old 04-06-2016, 04:06 PM
pectelboy
pectelboy's Avatar
Got mine off anembo , front and rear , same as genuine ford , fitted mint , don't trust burtons, had a few problems with some stuff off them
Old 04-06-2016, 05:06 PM
uk-doctor
uk-doctor's Avatar
carnt seem to find the front wheel bearings on there mate??
Surely a few people have something to say on this???
Old 04-06-2016, 06:29 PM
Mark V8
Mark V8's Avatar
I bought mine from matt Lewis Motorsport
http://mattlewismotorsportonline.com...aking-63-c.asp
Old 04-06-2016, 06:47 PM
pectelboy
pectelboy's Avatar
No mate gave him a bell,and he had them in stock
Old 15-06-2016, 06:38 PM
dal3door
dal3door's Avatar
Hello
Just to let you know I brought front wheel bearings for my 3 door and when I fitted them they just lock up and don't spin so don't waste your money on the burtons one I then got some off anembo engineering and they fitted fine
Old 15-06-2016, 07:49 PM
uk-doctor
uk-doctor's Avatar
oh god not good! Ive got them to change them for SKF bearings now theyve ordered them in for me so fingers crossed therle be goos ones
Old 15-06-2016, 08:05 PM
Ridgey
Ridgey's Avatar
GGR was where I got my bearings.
Old 16-06-2016, 07:40 PM
Hellraiser
Hellraiser's Avatar
matt lewis for me, heard lots of bad reports on Burton Power. if. matt aint got it in stock he will get it for you. always got time for folk too he has
Old 16-06-2016, 08:06 PM
I think the hub flange is common for wearing so the bearing is gonna be loose. When i first bought my saff a hub was worn on mine.
Old 17-06-2016, 08:45 AM
uk-doctor
uk-doctor's Avatar
I think im going to use Loctite 620 to secure the inner bearing race to the hub as even these genuine SKF bearings can wuite easily slide on and off the hub.
Has anyone else done this and used Loctite to compensate for the wear???
Because falling short of finding a brand new pair of Ford saph 4x4 hubs in the street lmao what can you do, all the used ones will most likely have similar minimal wear
Old 17-06-2016, 11:49 AM
155lee
155lee's Avatar
Why don't you measure the o.d of the parts you think are worn and compare?
The only part that could be worn is the section where the bearing sits,if there's no bearing running on any part of the machined stub then there's no way that can be worn so measure it in a few places with a vernier.
That will confirm if it's worn or not.
I'd doubt both hubs are worn the same or all 4 hubs,that would be near impossible so I'd guess either the bearings should be loose on the hubs or they are made wrong,doubtful though.
When I did my 2wd bearings I had to press everything together and those bearings were quintin hazel as supplied by ggr.
Wouldn't be putting them together with loctite either,wasn't in there from New and won't last.
Brickhouse
Ford Mondeo Including ST
20-07-2016 11:18 PM
clipper49
14-03-2016 06:47 PM
ajamesc
11-03-2016 01:30 PM
clipper49
10-03-2016 09:26 AM
kevin micallef
06-03-2016 05:36 PM
Quick Reply: Burton Power Wheel Bearing
