Pf09 / pf01
Pf09 / pf01
Hi
A mate of mine has a 1991 Sapphire 4X4 and has been having a few issues with idle and hunting on tick over.
We have checked for vac leaks and done a vac test and all is well, so my next thought was the TPS...
When i looked at it i saw that it had a "RED" TPS fitted and thought hey presto found issue as i thought all the PF01 sensors were red.
On removing the sensor is had stamped on it PF09.
Which i thought were all black.
Has anyone else go any PF09's that are red in colour ????
many thanks...
I think this is the problem the reading are all over the place.
Can some one confirm what readings should be at closed throttle and throttle fully open.
( PF09 )
Thanks
( PF09 )
Thanks
Roughly 0.5 closed throttle to 4.5 open throttle. iirc I set mine to around 0.35 closed throttle maybe even less but can't quite remember it was that long ago
jonmac1
09-05-2016 09:24 PM
uk-doctor
19-04-2016 02:14 PM
