Gt3071r cosworth ''during assembly''
Old 28-03-2016, 12:13 PM
shark91
shark91's Avatar
Default Gt3071r cosworth ''during assembly''
Hello everyone,
I live in Paris and I own a sierra cosworth 4x4 Engine full stock
I intend to set up a R GT3071 with an exhaust housing cosworth AR72. I chose this model because it retains the original exhaust line and the internal wastegate.
Have you ever ride this turbo? Loading later? Since that is on dual ball bearing but it is not a ar63
Thank you
Old 29-03-2016, 05:14 PM
Bart
Bart's Avatar
Very good turbo. I made a engine with gt3071 and made 432bhp@1.5bar
470NM torque at 3500rpm till 7000rpm
Old 29-03-2016, 09:37 PM
shark91
shark91's Avatar
hello Bart
Thank you for your answer
You speak of me with GT3071R cosworth exhaust housing?
3500 RPM for full charge turbo
It goes perfectly on the 4x4 exhaust manifold
you have a 4x4 or 4x2 cosworth?
Attached Thumbnails Gt3071r cosworth ''during assembly''-img_6177.jpg   Gt3071r cosworth ''during assembly''-dsc_2825.jpg   Gt3071r cosworth ''during assembly''-img_6182.jpg   Gt3071r cosworth ''during assembly''-dsc_2824.jpg
Old 30-03-2016, 07:09 AM
Marc sierra
Marc sierra's Avatar
Last year I was also looking at that turbo. But apparently it would surge and the boost needed to be mapped as well, which meant it would need a live map. Who is going to map your engine?
Old 30-03-2016, 10:19 AM
shark91
shark91's Avatar
Good morning Marc,
At the moment I am in full assembly of the turbo compressor. The most difficult has adapted this turbo is the oil return.
It touches the mounting studs of the flange of the manifold.
After about managing the mapping, I have a preparateur near my home that began in cosworth. MTR MOTORSPORT He took out 800 hp + on his old sierra
Frankly I think it is a good compromise that gt3071. After seeing a once mapped ...
Msd does not map on this config?
Old 30-03-2016, 10:48 AM
Marc sierra
MSD could do a live map, but no off the shelf chip for this setup unfortunately. So in the end I went for the tried and tested T34.48.
Old 30-03-2016, 10:53 AM
shark91
shark91's Avatar
Yes you did it is most common and least difficult mount.
In fact I have also taken this turbo because it is reliable and resilient.
And the day I forge the engine, I could keep this turbo.
Nobody who knows someone in England that this turbo?
Old 16-06-2016, 01:49 AM
shark91
shark91's Avatar
Hello
someone has pictures of his oil return assembly on this turbo ?
What have you chosen for arrivals and return water
Thank you all
Old 17-06-2016, 05:25 PM
Bart
Bart's Avatar
Originally Posted by shark91
hello Bart
It has a.63 housing. I ported this otherwise you have boost creep.
Turbo is fitted to 2wd manifold with spacer.
Ecu is a KMS MD35.
Old 31-07-2016, 11:53 PM
shark91
shark91's Avatar
hey guys
I still have not made ​​the engine reprogramming ...
If it keeps I'll sell my turbo t34 against an ar .. 55
I'm tired of waiting...
Old 04-08-2016, 08:01 PM
R4N SS
R4N SS's Avatar
i had a gt3076r 0.63 and it was horrible - full boost was around 4500rpm and it made 425bhp and 378 lb/ft on Omex 600 - was not happy
Old 05-08-2016, 11:47 AM
cossie2
cossie2's Avatar
R GT3071 with an exhaust housing cosworth AR72 is very good turbo...full boost by 3800 rpm..more than enough..
Old 25-08-2016, 09:45 AM
shark91
shark91's Avatar
bye bye gt3071r (is on sale now)
Finally, I drop the gt3071 because no prepareteur that can make me mapping
So I buy a t34 I am trying to clean up. I'll put my map 803 3 bar
How you breathe in turbo pressure to achieve 330 hp
I own exchanger airtec 60mn, bosch044, dump bailey double piston
T34
Bye bye gt3071r pity...
HeeganRS
11-04-2016 09:30 PM
jessie_rs
10-03-2016 05:00 PM
MalZon
21
20-02-2016 10:45 AM
Big-al-1978
06-02-2016 11:24 PM
Marc sierra
28-01-2016 08:56 PM
Quick Reply: Gt3071r cosworth ''during assembly''
