Ford Sierra / Sapphire factory sunroof resto?
Old 10-10-2016, 07:44 PM
  #41
costina
Live long and prosper!!
costina's Avatar
Originally Posted by Mark V8
That is pricey
I still want it though !
I have nos one Mark
But its not forsale
Old 12-10-2016, 08:21 PM
  #42
Mark V8
Mark V8's Avatar
Originally Posted by costina
I have nos one Mark
But its not forsale
Where did you manage to find that ?
Old 13-10-2016, 09:34 AM
  #43
costina
costina's Avatar
Ebay bargain find.
Old 19-10-2016, 03:28 AM
  #44
merkurdriver
merkurdriver's Avatar
That is pricey
That one has sold - is it making its way to you?
If no, there is ANOTHER ONE : http://www.ebay.com/itm/NEW-NOS-Genu...-/192000825842
Sorry to muck up the resto post again -- I would be pulling hairs doing the intensive labour Jack and the Beanstalk performed and commend those efforts.
Heres a shortcut if the piggybank is full.
Old 19-10-2016, 07:18 PM
  #45
Mark V8
Mark V8's Avatar
Not guilty I'm afraid !
Are these the same FINIS number as UK cars ?
Old 20-10-2016, 12:47 AM
  #46
merkurdriver
No FINIS number offered, only the SEKURIT number on the glass
Attached Thumbnails Ford Sierra / Sapphire factory sunroof resto?-s-l500.jpg
Old 19-03-2017, 01:21 PM
  #47
parrot
parrot's Avatar
Does the rubber just fit onto the frame? My point is does it need to be bonded/glued to the frame?
Old 20-03-2017, 08:26 AM
  #48
Jack and the Beanstalk's Avatar
I also asked this question and didn't get clear answers but went with bonding the seal with the bonding glue. Having said that i would recommend
From my experience with this resto, if I had to install just a new rubber seal I
would:
01. Heat the rubber, either in a hot water bucket or a quick-build hotbox with heat gun or hairdryer to get the seal a bit more flexible and easy to work with.
If your using hot water to heat the rubber, remember to blow the hollow tube out so water does not sit inside.
02. Do a test run installation without glue to determine how the seal sits and get a shape going. Start with one end of the seal in the middle of the back end of the glass. You have to push the Seal until it clips in over the lip. work the seal around until the two ends meet back in the middle.You might have some overdraft at the end, only cut this later on final installation as you will need to apply some glue where the two ends meet.
03.Once you happy with how it looks and is sitting correctly, slowly and carefully strip / peel the rubber seal out
Final Installation
04. I would recommend using a good quality moderate setting superglue gel for rubber seals or maybe even hot glue might work.
05. During final installation apply a spot weld technique with the glue to the frame to hold the rubber seal in position.
06. Once you get to the end cut the excess off to allow the two ends to meet and superglue together so it looks like one piece.
07. Go back and check that the seal is clipped in properly. Once satisfied allow to dry and settle for a day and install your panel.
Notes:
a) Prep is everything. Make sure you have your materials, tools and replacement part at hand. Work in a comfortable clean environment.
b) It can get messy, ensure you wearing gloves
c) Mask the glass and frame off nicely apart from where the rubber seal is going on.
d) make sure that the frame is cleaned and free from debris. If you have minor rust areas, try to attend to it best way possible. clean it up and paint it.
If you have major rust holes etc.....well you pretty much gotta do what i had to do or buy new off the bay or get a very good second hand one.
That is all I can recommend
Old 14-09-2020, 06:11 PM
  #49
Keith Chandler
Keith Chandler's Avatar
Default Have you still got this sunroof
There was replica saff sunroof seals on ebay a while back.
Im lucky i have a brand nos sunroof tucked away
looking for a complete one for mk1 Sierra xr4i
Old 25-09-2020, 08:26 AM
  #50
Hi Lads
I stumbled across this persons YT channel tackling a very rotten Cossy sunroof. Worth watching for some tips. As it appears I don't think he is finished and would be interesting to see how it turns out
Its in Japanese but are able to turn the translator on.
Enjoy
Old 25-09-2020, 09:04 AM
  #51
tosh
tosh's Avatar
I didn’t understand a single word that he said but I’m guessing there’s a certain amount of swearing going on I’m guessing you had the same amount of trouble?
Old 25-09-2020, 09:49 AM
  #52
Curse curse curse !!!!!! Oh I didn't see you standing there!
Old 26-09-2020, 06:44 AM
  #53
Unfortunately no translator this time round but quite interesting to see how he goes
Old 26-09-2020, 04:09 PM
  #54
cossynut2
cossynut2's Avatar
I think the Japanese guy has got a lot of skill to make up the new framework .I bet when it's finished it was a top job!!!
OZkaGas (27-09-2020)
Old 01-10-2020, 07:22 AM
  #55
It looks like he managed to finish it.
Looks like it works well for a complete brand new fabrication.
OZkaGas (01-10-2020)
155lee
13-12-2015 09:01 PM
Gary @ RS CLASSICS
09-12-2015 03:07 PM
25-11-2015 08:11 PM
loggie
23-11-2015 07:27 AM
dom1188
20-11-2015 04:29 PM
Quick Reply: Ford Sierra / Sapphire factory sunroof resto?
