Saff cossie lambda wiring
Old 23-11-2015, 07:35 PM
Default Saff cossie lambda wiring
I think ive wired my lambda up right but i just wanna make sure.
The lambda has 2 white wires and a black.
Ive got the brown wire with the white tracer going to the black.
The other brown wire has gone to one of the white lambda wires and a black wire going to the other white on the sensore.
I'm sure its right but u wanted to double check.
Old 23-11-2015, 07:42 PM
costina
Live long and prosper!!
costina's Avatar
white wires are heater glenn black will be sensor.
white wires can go either way.
Hope that helps
Old 23-11-2015, 07:44 PM
costina
costina's Avatar
check on your car loom you will have 12v feed and earth and sensor wire to ecu.
Old 23-11-2015, 07:45 PM
I think its right.
Old 23-11-2015, 07:47 PM
I will have to double check.
Old 23-11-2015, 07:50 PM
Tim Wharton
Tim Wharton's Avatar
Did you sort your Altenator problem Glenn?
Old 23-11-2015, 08:05 PM
Im on doing it as we speak. I took the alternator off then decided to clean some parts up in the engine bay.
Old 24-11-2015, 07:41 PM
Tim Wharton
Are the neaver ending cleaning
Mines not been back in long so it's still looking good
Its gone into hiding for winter now
Old 25-11-2015, 06:09 AM
Stunning that matey. Mine will never be as clean as that unless i take the engine out.
Cozzie94
18-01-2019 04:44 AM
bi55et83
14
23-03-2016 09:03 AM
mpilk
22-11-2015 12:58 PM
Mickeystewart
11-11-2015 04:28 PM
Quick Reply: Saff cossie lambda wiring
