Abs help going insane!
I've been trying to sort my abs out on my 3 door. I'm guessing before I had the car the abs had been bodged as words were joined to make it run all the time. I've put all wiring back to how it should be and the I turn ignition on but nothing happenes.
The warning lights come on bit that's it.
I've replaced:
another Ecu
Both pressure switches in the pump
All speed sensors
All fuses / relays but not for original not sure if would make any difference but the originals weren't in there to start with so not sure what ones they are.
I'm just stuck and it's all I need to be able to drive the car after nearly 4 years of a restoration!
I've replaced:
another Ecu
All speed sensors
Resident Wrestling Legend
do you have power when you turn the ignition to position 2? the radio one bit?
has the dash come apart? there were 2 plugs behind that under the windscreen, one for the fusebox and one for the ignition power, has someone unplugged these and not plugged them back again?
you've not burnt out the fuseable link from the battery?
Sierrasideways
07-10-2015 07:59 PM
