Number 4 plug getting wet ?
Number 4 plug getting wet any ideas?
Recently my car started missing. Checked it out and found number 4 plug to be wet with fuel. Cleaned plug swapped for another from cylinder 4, re started and run fine then after a few mins miss fire again, same problem number 4 wet. Done compression check and all ok, good spark too and injectors are only 800 miles old. It's run perfect for 800 miles denso plugs. Any ideas before I pull it apart again?
I've had the same problem this week with denso plugs,thought the engine shit itself for a start and then started with the basics and turned out to be a duff plug.
They're only a couple of hundred miles old too
lee2cossies (18-10-2015)
Mark
Fatphil
15-10-2015 10:02 PM
Matthew Buckel
14-10-2015 01:57 PM
Brocker
12-10-2015 07:00 PM
