C0 level closed loop ?
Old 25-07-2015, 09:03 AM
mattman1234
mattman1234's Avatar
Default C0 level closed loop ?
my car seems to be running rich on closed loop,when i disconnect it,it makes no difference,its reading between 11-12 on the afr meter,it does go up a tad when i put on headlights etc.
Any pointers to look for?maybe dodgy pf09
cheers all
i have checked the lamda ,and seems to be fine
Old 25-07-2015, 08:52 PM
costina
Live long and prosper!!
costina's Avatar
Have u tried tweaking the co pot?
Car must be over 70 degrees water temp to be on closed loop and afr around 14.7.
Faulty cps?
Old 26-07-2015, 07:15 PM
mattman1234
what is a cps ?
Old 26-07-2015, 07:43 PM
Adam-M
Adam-M's Avatar
Crank position sensor mate
Old 26-07-2015, 07:45 PM
costina
costina's Avatar
Sorry coolant temp sensor not crank.
Old 26-07-2015, 07:53 PM
Mark Shead
Mark Shead's Avatar
cheers all
Haven't you changed engine spec.
Mark
Old 26-07-2015, 07:55 PM
Adam-M
Adam-M's Avatar
Your AFR is roughly what mines is but I don't have closed loop, it actually used to running around 14-15 at idle but the mapper didn't like it.
Did your used to run a bit leaner and now all a sudden it's rich?
Old 26-07-2015, 08:36 PM
mattman1234
Mark
spec still the same at mo ,msd380 chip,want to change.I'm having issues with prop alignment at mo,although hopefully sorted now.
Had to take engine out again today,to adjust clutch form arm,5mm.
I'm slowly losing the will to live with the car at mo.
Old 26-07-2015, 08:37 PM
mattman1234
It all of a sudden went rich,went for mot yesterday,the guy said it was 20 times to high,so bypassed that test.
XR4
Ford XR Range
01-10-2015 12:46 PM
Marv888
26-09-2015 03:44 PM
IainRS1700T
25-09-2015 06:44 AM
tib2220
14-09-2015 12:33 PM
Quick Reply: C0 level closed loop ?
