New stroker kits
New stroker kits
Anyone seen this yet:
http://www.zrp-rods.com/default.aspx?id=3&cId=8&pId=902
So what CC do you end up with? Would you then need to buy different pistons or have these machined depending on what camshaft and valves you have and what compression ratio you are running?
Yeah, that is what I thought, trouble is that if it breaks it can take a lot of expensive bits with it.
It would also need spray jets and clearance of the block, For me 84mm is very tight in there,
The pistons have thin wall pins also and I think comp is a little bit high if you want to run a small turbo at lots of boost.
Mark
I hoped you would comment, at this level the engine builder is key
http://www.ikengineering.co.uk/index.php/products/crankshafts
There is also these but correct me if I'm wrong Mark 19kgs is very weighty?
He does rods to match for £525.
How much are oil squirt jets fitted nowadays?
Mark
