Spacers/Studs for Timing-Belt Cover,
Got a polished timing belt cover for my Sierra, Need a few bits to fit it and Ford cannot get them anymore so anyone know where I can get, 2 number 13s?
I assume standard ones are normally used to fit an aftermarket cover?
Could also do with all the studs/washers needed, Is their anyone doing a complete 'fitting' kit?
I used these last week,
M6 x 12mm
http://www.ebay.co.uk/itm/3213362409...%3AMEBIDX%3AIT
and these 18mm
http://www.ebay.co.uk/itm/2214490627...%3AMEBIDX%3AIT
M6 x 12mm
and these 18mm
i need the two bolts that go into the top of the cambelt cover and into the rocker cover (part 7 on the above diagram).
Can anyone point me in the right direction as to how to get these?
Even if someone could tell me the length of the bolts would be a good start. Thanks.
bought both of these over the last few weeks, first link arrived no bother and he has some more, second link seller seems to have some remade and the first set he listed went for 40 quid iirc, the second set i won for 28 quid but as yet (just over a week) they haven't arrived although they were marked as dispatched on the 15th
http://www.ebay.co.uk/itm/Ford-Escor...Z#ht_146wt_958
http://www.ebay.co.uk/itm/Cosworth-Y...nc#ht_40wt_958
Thanks for your replies. I've ordered the screws of the back of your advice 👍
As far as the spacers are concerned, there should be 3, right? I have sent the guy that sells remanufactured spacers a message to see if he can supply any more. I'm sure yours will be on the way, just via the slowest postal service ever 😂
