Sapphire rear light problems.
Been going through all the lights on my car and having a bit of a mare with the rear lights! When the o/s indicator is switched on the fog light and rear light also flash any ideas? The earth seems ok when tested with multimeter but the rear plug has seen better days! Anyone repaired theirs? Doubt the plug is available new from ford?
cossie fan (unluckerly)
Sounds like a bad earth. Multimeters can be deceiving as you can get 12v's or good continuity through 1 strand of wire. Load testing an earth with a bulb and a good known live is far better. I had to chop my plugs off and use small spade terminals.
KSA-Cossie (24-01-2015)
If your any good with a soldering iron the way i have fixed a friends sapphire massy tree lights at the back take the light apart if the connector is that shot, solder some flying leads directly to the pcb strip where the connector would push on cut the old connector off, then used tamiya connectors and re loom the wire, its also a good idea to run a new earth from the light pcb directly to the chassis i used a built connector for this,
the reason i replaced the lot was when going over bumps the fault would appear and disappear as the connector moved
hope that helps
hope that helps
If your any good with a soldering iron the way i have fixed a friends sapphire massy tree lights at the back take the light apart if the connector is that shot, solder some flying leads directly to the pcb strip where the connector would push on cut the old connector off, then used tamiya connectors and re loom the wire, its also a good idea to run a new earth from the light pcb directly to the chassis i used a built connector for this.
Paul_RS (15-03-2015)
Received 1,042 Likes
Ive got i similar problem with my saff. When the brake lights are on and im indicating the brake lights are flickering. When checked for a live feed on my power probe it said 9volts.
mrice0107
21-08-2015 07:55 PM
sridgett
15
03-08-2015 07:26 PM
