4x4 sierra no spark...
Hi,
i raced my 1990 sierra 4x4 cosworth on a bumpy tarmac/gravel track yesterday and the engine cut off suddenly, could not restart it since.
The fuel pressure and the coil is ok but no spark to the plugs any more
The car is modified by the previous owner during the years for better performance, lot of dodgy wiring unfortunately, old cables, connectors so it's an electrical nightmare. All i know it has a T35, chipped ecu, standard coil and injectors, very stiff suspension.
Probably the lot of shaking the car got during the race could have caused the problem but I have no clue what to check, any suggestions would be appreciated.
There is no visible sign of broken cables or connectors but i can recheck whatever you suggest.
Hi Martin,
there is a fuel pressure gauge fitted and the fuel pump is switch operated so when i flick it, i hear it running.
i've checked the CPS connector, not loose at all.
Results:
10) CRANK SENSOR: Check resistance between pins 3 and 4 between 300 and 1200 ohms. - There was 0 ohms between the ecu pins but when i disconnected the plug from the cps, i've measured around 700 between the plug terminals.
11) CRANK SENSOR: Check AC voltage on pins 3 and 4 while cranking engine - should be at least 2V. - This was zero...
16) IGNITION TRIGGER: Read voltage between pins 24 and 25, should be at least 4.5V. - This was only 3.75V
SIERRA RS 4X4 COSWORTH
check the 3 multiplugs on the bulkhead above the rear of the camcover also check ignation amp .. crank sensor multiplug behind the dizzy, and phase sensor connections inside the dizzy ,
And check all teeth are on the crank pully , seen dodgy cambelt changes crack the pullys .
Goodluck
Goodluck
Was gonna say above too check the crank pulley lugs if you hit the gravel hard enough potentially could have damaged one causing problems.
I had a bolt come loose ones which chipped one, was fine till I backed off then cut out. Checked over everything loads of times then then realised what had happened!!
truffleshuffle
10-09-2015 09:35 PM
Adam Graham
06-09-2015 06:04 AM
