comp brake pedal box
Old 19-10-2014, 09:26 PM
binks101
binks101's Avatar
Default comp brake pedal box
Hello all as above anyone using them are there any good?
Old 21-10-2014, 08:56 PM
jamie956
jamie956's Avatar
My experience of them is not good, poorly made and not very well engineered.
Admittedly I have altered an escort one to fit in my Cortina but that's only the mounting points, had loads of issues getting clutch to work with crap pedal ratios and brakes are poo which I also put down to the pedal box.
Old 21-10-2014, 09:44 PM
binks101
binks101's Avatar
Not good then mate:/
Old 21-10-2014, 09:57 PM
binks101
binks101's Avatar
What other companies sell decent pedel boxes??
Old 22-10-2014, 04:59 PM
jamie956
jamie956's Avatar
What car is it for,
Old 22-10-2014, 05:02 PM
paul16v
Monte 087
paul16v's Avatar
Tilton make very good pedal boxes, avoid compbrake/obp cheap tat.
Old 22-10-2014, 06:17 PM
andy escos
andy escos's Avatar
I had a comp brake pedal box and they are crap the pedal ratio was 3.5 to 1 which is bad Tiltn do excellent pedal box,s which are upto 6 to1 which is very good
Old 22-10-2014, 08:03 PM
binks101
binks101's Avatar
Originally Posted by jamie956
What car is it for,
3 door jamie
Old 22-10-2014, 08:05 PM
binks101
binks101's Avatar
Cheers Paul and Andy will look them up!
Old 22-10-2014, 08:26 PM
Richie.
aka Turbosailorboy
Richie.'s Avatar
Location: Under the water.... .......in a nuclear submarine
Got both my Tiltons via these guys: http://www.competitionsupplies.com/tilton
Good advice and top service
Old 22-10-2014, 08:54 PM
jamie956
jamie956's Avatar
3 door jamie
I think unless your doing an all out race car changing the pedal box can be a lot of hassle for not a lot of gain. I don't think any of the tilton boxes are going to be a straight swap there likely to need a fair amount of fab work to fit.
Old 23-10-2014, 08:45 PM
binks101
binks101's Avatar
doing all the fab work now jamie like roll bar mounts engine mounts etc some making a bulkhead mount shouldn't be a problem
Old 26-10-2014, 11:48 AM
Sonic Boom
Sonic Boom's Avatar
I have to say I got excellent service from CompBrake after speaking to David @ the Autosport show at the begining of the year.
I was after a dual master cylinder setup which bolted in place of the original ABS master cylinder which they did for many other cars off the shelf but not the Sierra.
He said no worries send me a ABS unit and I'll copy the bolt pattern and make you a custom one which he did for no more money than a stock item.
You can now buy a sierra one from CompBrake
And it's been faultless all season so much better than ABS setup.
Rich
Old 26-10-2014, 11:59 AM
markk
markk's Avatar
With Compbrake it does depend on who you deal with.
Old 26-10-2014, 05:34 PM
Sonic Boom
Sonic Boom's Avatar
Here's a couple of photo of the my Dual Master Cylinder setup from CompBrake before I fitted it:
Rich
Old 26-10-2014, 06:00 PM
matthewpickup
matthewpickup's Avatar
I bought one , a direct replacement .... there was nothing direct about it , my brakes are crap and would cause you to crash , I called them and asked about fitting , and if they would do the job , and after giving them around £500 I am now taking it back out as its no good , I have no idea how they get away with selling this , trading standards wants to be giving them a talking to as its not as they say .
Old 26-10-2014, 06:10 PM
Sonic Boom
Sonic Boom's Avatar
The same as mine above?
Rich
Old 26-10-2014, 06:20 PM
matthewpickup
no not the same at all , which is strange but maybe its so they could say its direct replacement , as its basically just a standard peddle box modded to have the two master cylinders and balance bar
Old 26-10-2014, 06:27 PM
Sonic Boom
Sonic Boom's Avatar
What you want is what I had above mate, it does just bolt straigh on you don't have to touch the pedals at all other than to disconnect the old rod and connect the new one.
Rich
Old 26-10-2014, 06:32 PM
matthewpickup
yea that was the kind of thing I was wanting , how much was it if you don't mind me asking?
Old 26-10-2014, 07:06 PM
Sonic Boom
Sonic Boom's Avatar
With the box, both master cylinders, in car adjuster, 2 x pots with remote lines and brackets £300 all in
Rich
Old 26-10-2014, 10:42 PM
matthewpickup
Rich
that's good , wish I had seen this before nevermind I know now
thanks
yatta
21-05-2016 10:31 PM
Ford Focus RS Parts for Sale.
09-03-2016 01:03 PM
05-11-2015 08:12 PM
03-11-2015 04:08 PM
natehall
Ford Focus (All Models)
08-09-2015 05:13 AM
Quick Reply: comp brake pedal box
