Prop doughtnut 3Door cosworth
Hi, has anyone got a picture of one fitted as I think mine has had it and should be getting my new one this week . Hopefully it will stop the vibration under the car .
Also whats involved in fitting it
Dave
Dave
The only thing on a 2wd prop are these items
http://www.burtonpower.com/propshaft...95-propcb.html
http://www.burtonpower.com/parts-by-...r-propcbr.html
Cosworth parts for sale .
That's what i've got coming brammer . did you fit a new one? I'm hoping its stops the vibration I have on the car . I will change the gearbox mounts next but Just wasn't sure how its fitted
Simple you either split the shaft or theirs a bolt in one end and i think you can remove this to spilt the shaft and remove the centre bearing housing and replace the parts in minutes i think if it's Lee you bought it from hasn't worded it right it will be the parts i've listed above or you've bought a part not compatible to 2wd
Ford Focus RS Parts for Sale.
09-03-2016 01:03 PM
Adam Graham
06-09-2015 06:04 AM
