Rear beam bush help
Rear beam bush help
Hi all just tried to fit the rear beam on the cos, & it's as if the bolts aint long enough to get a thread to tighten?? I've had new power flex bushes am I doing something wrong?? Or is there a special way of doing this?? or do I need longer bolts?? It's the long 1's out of the 3 I mean. Thanks in advance.
Durham RSOC member
Bolts are correct as its fiddly to do with new poly bushes till they've been in and squashed abit. Theres a few ways to do it either put other 2 bolts in till you can get big bolt in or some people use a jack as you only need a few mm to do it.
Ford Focus RS Parts for Sale.
09-03-2016 01:03 PM
03-11-2015 04:08 PM
