Cosworth ABS sensors
11-05-2014, 04:05 PM
Are the ABS sensors the same for both 2wd and 4wd Sierra cosworths on the front?
Part number:- 6175345
11-05-2014, 04:24 PM
Iirc they are different
Luciano
11-05-2014, 04:28 PM
Round (2wd) or squared (4x4) connector iirc.
11-05-2014, 04:39 PM
The ones I have are round connectors but def fit 4x4 :s
11-05-2014, 04:42 PM
Pick-up P100 Power!
It's only the late 4x4s that differ. Most are round plugs, the later ones are oval.
11-05-2014, 04:45 PM
All the saffs and 3drs are the same. The escos ones are different.
11-05-2014, 04:48 PM
Pick-up P100 Power!
Think some of the later 4x4 saph had them too Glenn. A bought a complete rear beam out of a late saph and they where oval.
11-05-2014, 04:52 PM
I thought it was just the escorts that were different. My Jreg 1991 saff has the old style round plugs.
11-05-2014, 05:45 PM
My friends 93 has round plugs too iirc
11-05-2014, 06:01 PM
I'm looking at buying a pair from David.
Here's a pic of my connectors
I did not know if the different 2WD and 4WD part numbers were to do with the amount of teeth on the abs ring
Microcat info is:
2WD Finis 1654336
4WD Finis 6175345
Thanks for any info
11-05-2014, 06:24 PM
Here is ones I have,
11-05-2014, 07:00 PM
Quote:
Originally Posted by
Mark V8
Microcat info is:
2WD Finis 1654336
4WD Finis 6175345
Thanks for any info
The difference may be the wire length. My loom (4x4) extends further towards the front of the car than in the photo you've put up.
11-05-2014, 07:18 PM
I cant get over the price of them new.
13-05-2014, 06:13 PM
Anyone know 100% if the 4x4 ones are compatible with the 2WD set up?
I do not want to buy a pair that give me problems when my car eventually goes back together
13-05-2014, 06:22 PM
Yes there compatible,I put a 2wd one in my 4x4
13-05-2014, 06:46 PM
Im sure ive got a 2wd front sensor on my 4x4.
01-02-2015, 03:10 PM
Live long and prosper!!
How much !!!!!! even for a pattern part lol
original
30-01-2022 08:20 PM
manuel boeckx
13
03-10-2015 02:29 PM
Tim Wharton
30-08-2015 05:46 PM
rdvil
Other Marques
15-08-2015 12:11 PM
14-08-2015 07:29 AM
