What next?
What next?
I'm at a point with my car where I don't know what to do next. My spec at the min is standard 4x4 head with bd14 inlet, 200 block proper long studded, cosworth racing forged pistons with valve cut outs, standard crank, grey injectors, t34.63
What do you think I should do next? I was thinking change the turbo for something else or headwork etc. where do you think my money would be best spent and on what? I would like it a little less laggy as I prefered how it drove with the .48 housing
Billy
Billy
Borg turbo seems the way to go, I am doing this with modern ecu (vipec) , new loom coil on plugs and then add a close ratio box to keep it all on song.... I think head work will release more power but not sure on the low down side of things.....if you preferred the smaller turbo then the Borg is the first start as it will out spool and out power the smallest t34.
