909 Top mounts fitting problems
I get a set of 909 top mounts from the bay, now i have problem..
The top peace will not fit into the top rubber, i tried with oil and all my body weight, but they
will not get in without destroy the rubbers..
is there any trick or something to fit them??
Mate, I might be wrong here, but I'm not sure you can fit those with a regular rubber bush from a road car.
Mine are similar but are bolted to an eccentric top mount that goes on the underside of the turret, and the part on the top side (similar to the one you've pictured) carries a bearing that the threaded rod of the damper fits through, and is secured by a top nut. There's no rubber bushes involved.
Hope you find a solution.
Iain
Iain
They must fit into the rubbers in my opinion, here are the link from the pay and
of a thread from here with similar ones:
http://www.ebay.de/itm/331101695857?...84.m1439.l2649
https://passionford.com/forum/genera...op-mounts.html
Use soap.
They are designed to be used with the original bushes IanRS1700T has different mounts. Also, fit the mounts to the rubber BEFORE you fit the shocks. You need a tool to tighten the top nut ass well.
These are mine fitted
matman
09-09-2015 05:45 PM
track.focus'd
12-08-2015 05:53 PM
