cosworth looms
heffo
cosworth looms
ok guys ive had electrical problems with my 3 door i decided to change engine loom .when i fitted new braided loom i discovered it was a saphire loom and has one 8 way plug to plug into main loom where 3 door loom had 2 plugs a 2 pin and 4 pin .i want to cut wires and put on 2 plugs has anyone any idea what to join to what .i saw a thread on this before but cant find it now.
Paddy
Surely better to sell loom and get the proper one instead of introducing more joints, losing the reliability you were searching for when you bought a new loom ??.?
Resident Wrestling Legend
can you not just trace the loom back on the 3 door and swap the pins over?
shouldn't be too difficult?
but if you want a brand new loom, then i'd be very wary about who to go to, only go with someone who's been recommended here within the thread you post up if you decide to go that way
Paddy
Just thinkin , surely the 2wd looms are all the same with no multiple plugs??
Cossie loom doesn't join car loom (lights/heater/fans etc) runs eng only and at one end you have ecu and about five wires to connect , batt plus,neg,coil,revs and fuel pump and just sensors along the length
heffo
loom
thanks guys i think i will meter out cores and pull out pins from 8 way plug and push them back into the two small plugs . there was a thread on here before showing what each pin was but i cant find it .from what ive read it plugs into main loom for revs /fuel pump/pos neg etc.
http://www.turbosport.co.uk/showthread.php?t=352901
http://www.turbosport.co.uk/showthre...wiring+diagram
i found these paddy ,it shows which goes where .
heffo
loom
hi james .thats a different plug again i will send ya a pic of plug i have .the loom i got off you has all pink wires as its an aftermarket so core colours dont match drawings you posted.
big_Rad
15-09-2017 09:36 AM
muz
16-08-2015 12:57 PM
