SECS fitting instructions
Can anybody send me a link or a file to this please? Its for a 92 Sapphire.
Cheers in advance
Huw
Cheers in advance
Huw
BLACK > ECU PIN 1: GROUND
RED > ECU PIN 20: 12V POSITIVE SUPPLY
GREY > ECU PIN 25: IGNITION SIGNAL FOR RPM READING
GREEN > ECU PIN 17: THROTTLE POSITION SENSOR
BLUE > ECU PIN 29: ENGINE COOLANT TEMPERATURE SENSOR
YELLOW > ECU PIN 31: AIR CHARGE TEMPERATURE SENSOR
WHITE > ECU PIN 15: MAP SENSOR
Rich
Rich
Rich
Rich
Whats the recommeded way to attach these wires as you describe without comrimising the feed to the ECU?
Huw
Daisychain
22-08-2015 08:12 PM
