Brake lines - Can you still get them?
Im at the stage now i need to put in my brake lines, rather than making them all up i would ideally like to buy them. I see that some guy on fleabay is selling them but seams a little pricey. The only one i need to make up is to run up the ladder chasis of the P100. All the rest can be std sierra.
Any ideas guys? Cheers
the problem I would have with them pre made is that in the factory the lines are one of the first things to be fitted and as such you would need the subframes etc out to fit them they would be grand if that was the case but if you were just replacing lines it would make a big job out of a small one
Stage 1 Motorsport is the seller
Item number 171014878537
Stainless steel replacments. Ł115 pluss postage
That's for fuel lines, they also do brake lines
Is there any news on the brake lines & or fuel lines as I'm doing a underside at mo on my saph & am running braided fuel lines at mo but would prefer go back standard, & while I'm there I'll replace all the brake lines to??? Any help would be much appreciated.
