Adam to remove the fuel rail end of the pipe cut through one side of a 15mm copper olive and push it up the fitting to push the spring apart then pull on the hose I should pull out with a god pull, hope what ive said makes sense.
I dont fancy getting things brazzed on m8, just more to go wrong and more work.
Does anyone know if theres much preasure in this pipe?
Could i jubile clip abit of fuel line hose on here?
Its holding me rite up this bloody fuel line, Fords no longer stock this part.
Dash fittings brazed on are fit and forget so not more to go wrong!
But it's only pump pressure so a hose clamp will be fine I've seen a few like it but not ideal really as I don't think there's a flare in the pipe for the hose clip to clamp up before
In pict above shows you type of tool. The other pipe you either have a tool to push up in slots then push and pipe comes off or pull cover off and push the ring.
