Cosworth header tank information needed..
Thanks for the info Marco I've already got Samco water hoses but i'm going all braided hoses under my bay..
One hose is causing a nightmare is the header tank ---> Turbo pipe.. As it's 10mm (internal diameter) turbo end and 15mm the header tank end
As no braided company makes an increasing size along the pipe, so going to make an adaptor to slide into the header tank so it accepts an 10mm pipe!
Then (fingers crossed) i can get a 10mm braided hose and complete my set
That was my plan if the header tank slider didn't work. Gave one of my work friends the job of making the connector. fingers crossed it comes good!
Then I might do what you say about putting the connector in the middle near the cam bbelt cover
I'll post a picture when I'm done (if I sort it )
Danielbetty
23-08-2015 08:25 PM
155lee
14-08-2015 11:21 AM
