Electrical power steering
Old 17-03-2012, 06:07 PM
dal3door
dal3door's Avatar
Default Electrical power steering
Can anyone help me I any restoring my 3door Cosworth from scratch and all my power steering parts needs replacing and I was just thinking about converting to electrical power steering has anyone done this and help me in which parts to get for the best result and how easy it to convert thanks for the help
Darren
Old 17-03-2012, 10:34 PM
cossiestu
cossiestu's Avatar
Id be interested in this, there was a thread about this recently, mentioning using a Corsa set up on, I think, a mk4 Esc.?
Old 17-03-2012, 10:55 PM
botters
competant bodger
botters's Avatar
using the electric pump off a saxo would be the easiest way as you would only need to wire it up and then fit the hydraulic pipes onto your rack, if going the corsa electric column way you would probably have to chop your dashboard about and then find a manual rack
Old 17-03-2012, 11:13 PM
ajamesc
cossie fan (unluckerly)
ajamesc's Avatar
my mate has done it with a merc a class set up! i thought about it but couldent think of where to put the pump as i dont have any room under my bonnet
ajamesc
ajamesc's Avatar
saxo pumps are massive!
Old 18-03-2012, 12:04 AM
botters
competant bodger
botters's Avatar
yes but they can be remote mounted, ive seen them in spare wheel wells lol!
Old 18-03-2012, 12:06 AM
Cossie Sean
big floppy donkey dick
Cossie Sean's Avatar
Citroen C5 style can be remote mounted anywhere, as can most modern elec fluid type
brand new is only £380 also, result!
Old 18-03-2012, 12:08 AM
NATH-RSZT
NATH-RSZT's Avatar
I fitted a corsa setup to my mk4 escort estate with ease, there's a few pics on my rebuild thread.
Old 27-03-2012, 09:28 PM
karlthomas
karlthomas's Avatar
Why what is the benefit of removing the mechanical pump and replacing with electric?
Old 27-03-2012, 09:33 PM
NEEDFORSPEED
NEEDFORSPEED's Avatar
wired a fair few up pn race cars they use the corsa setup with a little control box connectoed to a potentiometer to adjust how much effort you want it to give you. if you want to source the parts i can get a prive for the box of tricks if you want
Old 27-03-2012, 09:34 PM
NEEDFORSPEED
youl get rid of a lot! nasty hoses etc
Old 27-03-2012, 09:36 PM
karlthomas
karlthomas's Avatar
What about this "saxo" pump that will keep the hoses? And could you make it up with a saxo pump to only be switched on at slow speeds so you get more "feeling" though the wheel feeling what the Tyers are doing more? Or is that only for the "corsa" electric setup?
Old 27-03-2012, 10:27 PM
NEEDFORSPEED
i cant see the point in swapping from the standard hyd rack pump and hoses to the same setup just with an electric pump. the corsa setup is such a neater job. wired up 2 on series 1 landrovers used for offroading well over 2 years ago now and are stil going strong so just goes to show how much theyll actually take!
mark94
Ford Mondeo Including ST
10-10-2023 06:52 PM
tankybaby66
06-02-2016 02:24 PM
01-11-2015 06:53 PM
07-10-2015 12:56 PM
stevecfrst1
30-09-2015 05:18 AM
Quick Reply: Electrical power steering
