Interior lights staying on
I recon its probably a shorting door pin but havnt had time to check, can you get new pins from ford anymore,may be the same as more modern fords.......
What he ^^ said, the relays most likely stuck!
No modern switches are different, and instead of just a plastic pin most are now encased in rubber and are near the door lock itself, rather than near the door hinges, for this reason these have two sets of switches per door (High spec models only).
Both types complete the earth circuit though.
The boot light won't make the interior light illuminate!
Martin
Martin
Martin
Martin
Martin
The Enigma
12-09-2015 10:12 PM
