2wd Sapph rear brake options.....
I have AP's 4 pots on the front of my car and they are awesome and i was thinking of upgrading the rears what options are there and are they a good upgrade?
Thanks in advance
Tarren
Thanks in advance
Tarren
cossie fan (unluckerly)
i have 4x4 stuff on the back of mine and also have ap 4 pots with 330mm discs never found my brakes not enough on the road with 500bhp
I fitted 4wd rear brakes on my 3 door, you need discs calipers and brackets. Easy conversion and no handbrake problems, you can also get a 300mm rear disc kit but doubt it would offer any real advantages other than looks
I use APs at the front with a 4X4 rear brake set-up and find that I can lock the rears before the fronts on track - so you'll be fine with a 4X4 set up at the back. The 4X4 discs are vented so runs cooler where 2WD is not. The fronts do all the work anyway. And as you see, you get to keep the original handbrake. Charlie
track.focus'd
12-08-2015 05:53 PM
