Are these cheap fans better than the std. ones?
I was always under the impression the std fans were fine - mine used to work well and the only reason i changed was due to larger radiator so no room.
As for the ones in question i did read on here that someone fitted a set and the failed very quick, 3 weeks if i recall but you never know they may last, is it worth the risk though
I use the exact same ones mate... And there well worth the money and upgrade...when they come in if I stick my hand behind them.. They feel like they are flowing more than standard cossie ones and quieter.
Fast Ford snapper
You got to take into account the wear in the old original fans. I recently had my fans diagnosed as drawing too much current n the drift car when getting some charging issues sorted..... planned to replace them after the next BDC round, but ran out of luck when they melted a lot of the car's loom on the start grid! Almost went up in flames....
Chip I've ran kenlowes before and I don't see any advantage apart from a bigger price tag... My fans are only in for 1 min at a time... As I have alloy rad , updated fan switch.. Updated thermostat and fan loom... All that makes my cossie run a 1000 times better.
*** Sierra RS Custard ***
But obviously the problem with "ebay fans" is that isnt a make, so they may vary, but the couple of cheap ones Ive tried have been pretty pony, hence when I bought one to replace the not up to the job ebay fan I had on my clio till recently I bought a proper kenlowe one instead.
Sounds like your radiator is good enough you hardly need a fan, and that you dont sit in traffic much anyway, so yours probably isnt really testing the fan very hard in reality.
PRO-LINE MOTORSPORT
28-09-2015 09:54 PM
SMILER258
28-09-2015 09:04 AM
