brakes
05-09-2011, 06:50 AM
brakes
Just fitted 330 front hi spec set up with 6 pot calliper. But oz superleggras are hitting calliper any suggestions
05-09-2011, 06:58 AM
Resident Wrestling Legend
05-09-2011, 07:04 AM
Quote:
Originally Posted by
dojj
buy different wheels
What wheels will fit over them
05-09-2011, 07:43 AM
comps seem to be the ones with the most clearance
ring hispec and ask the dimensions you ned to ask for cleanrace wise as they should be able to tell you what wheels will clear and what will foul
how much do yours hit by, mm's or inches?
05-09-2011, 08:23 AM
YOREVOL
you must have been up early to do that job!
05-09-2011, 08:30 AM
cossie fan (unluckerly)
if you dont want to change wheels get longer wheel studs and fit spacers! i had to with mine fitted 5mm ones!
05-09-2011, 10:11 AM
Cheers for advice everyone I put three washers on yestetday just to see how much clearence I need its about 10mm
05-09-2011, 11:49 AM
10mm might be enough to get away with using just a 10mm spacer and the standard wheel nuts/studs
05-09-2011, 01:34 PM
i would still use longer studs if using spacers - i may need them with mine as my rs7s wont fit over my 330s
05-09-2011, 01:37 PM
they fit on my car and i have a OFFSET wrong wheels !
i got the tsw ones in gold as a spare set and they fiit to !
05-09-2011, 02:21 PM
RS500/364
What ET offset do you have? I'm on the lookout for wheels to fit over Focus RS discs with Brembo calipers on a saph.
05-09-2011, 02:38 PM
R4N S S
never in a month of sundays mate, you'll have to change your rims
05-09-2011, 04:50 PM
dojj
i needed longer ones with 5mm spacers you should be looking for at least 5 threads in the nut
05-09-2011, 07:05 PM
Update......12mm spacers fitted wheel clears caliper now but wheels are sitting out way to far what offset wheels should I be using as mine are et 37 been told this could be the problem
05-09-2011, 08:10 PM
the offset won't make a difference, it's the shape and clearance of the rim
i've got a shallower offset on my mondeo rims by 12.5 mm on an et40 instead of an et52.5, but the spokes clear the brakes by 5mm and i would have needed a 15mm spacer on the standard rims
muzzman1
30-09-2015 08:59 PM
Sp3no
27-09-2015 07:23 PM
