3DR Cossie - Aftermarket Alloys - Advice
Hi Ya…
I am just about to order the following for my 3DR.
Front 17" x 7.5
Rear 17" x 8.5
I can order them in any offset as the wheels are blanks at the moment.
What "offset" should I go for, naturally I want the best looking (not sucked under look).
I have standard brakes and the wheel arches are not rolled/trimmed which I want to avoid doing. The car has lowered springs (approx 1 inch) but I also have the original springs if need be.
The shop suggested +25 for the rear and +20 for the front which they got from an old BBS wheel fitment guide book.
Thanks guys..
MB..
Front 17" x 7.5
Rear 17" x 8.5
Thanks guys..
MB..
Thanks everyone for your input and photos, wow.... some nice looking 3DR's....jealous of all of them, hopefully mine will look as good once finished.
KODAK - just to clarify, when you say your offsets are the same as Rich "mentions", are you referring to what Rich recommended (Front ET35 & Rear ET25) or what Rich has on his car (Front ET33 & Rear ET23). And are your rims 17 x 7.5 & 17 x 8.5
Thanks again everyone.
MB..
MB..
Once again, thanks for your help......
So your's are "8.0" on the rear........ the ones I am getting are going to be "8.5" (I can only get them in either 7.5 or 8.5).
I am wondering if the "8.5" with ET25 on the rear will be OK or should go for a different ET on the rear. Any way, I have got the front ET sorted so far.
My next question is going to be "tyre" size you are running.
MB..
Simple solution to this is don't lower it too much - mine used to catch with standard arches front and back
Mine are 8.5 rear with ET22 and they used to touch the arches but i was running the car this low on coil overs - you need to go for a bigger tyre on the rear i got 215/40 then realised they were 8.5 and not 8 as thought but their is 225 but i think they only do them in 35 profile, for a 40 the next step is 235
This is now with all arches sorted and the rear lifted
BRAMMER - so what tyre size are you running on the rear now...... still the 215x40 or did you change up to 235x40.
Cannot find 225x40 here in OZ, only 225x45, scratching my head here a bit.
MB..
MB..
3dr cossie
21
20-11-2015 05:00 PM
oilman
Trader Parts for Sale.
30-08-2015 08:37 AM
