ecu
Very simple, you need a L8 ecu, 4wd tps, and to swap the outer two wires on the tps around.
The tps is around £35 NEW from your local ducati dealer, then obviously injectors map/chip etc to suit what you want.
They are normally around £45 with free post on begay, but have seen them for £35 at one point, a huge saving on paying the cosworth tax some want.
Just one of the many many reasons I'm glad I ditched the atiquated ecu that was in my car, tps for mine is £20 and takes but 30 seconds of laptop to set up, even if it reads opposite it can be inverted with a mouse click.
PassionFords Creator
I usually buy in 100s, which is why I was the cheapest supplier of them in europe for many years. So, you stand to make a cool £1000 for a weblink to my PM box here.
Loads available off other cars mate.Pop into your local scrappy and get looking for a rusty Lancia delta,turbo 8v has a L6 weber ecu so i don't think that'll work properly but if you could source a 16v twin-cam turbo version your set(black bodied PF09).
Try and locate a scrapped Fiat coupè turbo-16v and grab the sensors off that motor,age wise the coupè's are the youngest of the lot,how about trying the fiat dealer for a new one?.
Other cars that have the same/similuer sensors including the expensive idle control valves are:Fiat tempra 1800cc twin cam engines,Fiat croma 1600cc twin cam engines(not the turbo 8v version,all Bosch stuff),Fiat tipo 2000cc 16v,Lancia dedra 1800cc...basicly every old '90's Fiat/Lancia.
Almost forgot these shitheaps,various Maserati bi-turbos,222's,224's ghiblis...
well i got one its brand new must be the last one ever as i rang everyone and they all laughed and said if you can find more than one ring me and there have the others the only down side is it cost.............................................. .................................................. .................................................. .................................................. .........£185think they saw me coming but needs must
DixieTheKid
14-09-2015 09:04 PM
