2wd clutch arm pivot
I have just bought a t5 gearbox to install in a 2wd Sapphy i am restoring
and it has not got a pivot pin in the bell housing to attach the fork on to.
Where the pivot arm fits there is only a tiny hole in the bell housing.....
on the mt75 4x4 box it it quite a big hole that a pin fits into for the fork to
attach.
What should be there on a 2wd?
I have been on to Ford and they say that the part i need is no long serviced
and the picture is really bad.
Has anybody got what i need? or any ideas.
attach.
Cheers chrisa3 that is great! I saw this on the picture from Ford but it looked nothing like
that on the micro picture.
Any idea where i can get one?
Was your the same before you modified it ajamesc ?
I might have to go your route if i can't get one.
Many thanks for the link and info!
cossie fan (unluckerly)
So lets get this right........ if i drill the dell housing and use an m6 bolt,are you using two
nuts on the thread,because the fork has a slot in the end?
So you are just screwing in a short bolt and the fork slides under the bolt head?
Sorry to sound dim.............
So what is the back of the fork pivoting on.....the bell housing casting?
But...as the clutch cable pulls the fork, the opposite end of the fork is pushing towards the gearbox on the bolt you have fitted.It must just push on the raised area under the bolt in the bell housing..........?
Thanks for the advice i will go with your idea as i have had no joy getting the original
part and your idea sound tried and proved.
This is another car i am building.....i can't believe i had my own cars gearbox out two
weeks ago and didn't take any notice of the setup!!!!
I fitted an AP paddle spinner plate in mine with a standard cover,see if it lasts Ford Fair this year................thanks for you help mate.
