2wd Pistons + 200 block
Zee Germans are coming
4x4 pistons ahve an off set pin so the piston gets pushed up the bore in a better way
but if you by new pistons then they all ahve the off set pin now anyway
ALL YB PISTONS 2WD AND 4WD HAVE OFFSET WRIST PIN, the difference is 4wd have more offset, it's not detrimental in any way other than annoying some people, if it doesn't go away when warm then you have a little wear, but will still go for miles, mine had piston slap when hot, but still managed 200,973 miles before it was taken apart, compression was fine, as was mpg, and emissions, it did 40+ mpg without especially trying, emissions were 0.97% CO, 137PPM, with 190,000+ on it.
The oil rings went like overnight almost, and started drinking oil at 1L every 10-15miles, hardly smoked at all though.
The 2wd degree of offset hasn't been used for years, I'd be seriously amazed if it was still used, the reason for the offset is the thrust of the piston as it is pushed down the bore it tries to rock, the offset is to counter this.
4wd yb were reworked in several ways, one way was more offset to the wrist pin, hence less noise.
Have the correct tools to measure the offset of the wrist pin.
If they are under 10 years old I would be amazed if they had the original 2wd pin offset.
There has been significant material changes over the years, so any cossie engine built now benefits from this, and would likely have a tighter bore clearance, I run 1+1/2 thou bore clearance for example, the pistons contain massive steel straps inside the casting so they don't expand as much as before, this is one way in which the materials have got better.
I know my engine is new but there is NO noise from cold, not even half a tap from a tappet, these have done 80,000+ miles, but I cleaned them out, they are INA, made in germany(they have factories everywhere) but they are nothing special inside just bog std same as all the others I've cleaned out over the years.
timsrs
22
24-09-2015 08:14 PM
