What pistons
What pistons
As title whats the thoughts on best pistons to bye for a early 2wd 205 block gonna need 0.5mm overbore, aiming for a nice strong 300-325bhp engine.
Someone recomended the wisco pistons std comp with cut outs speaking to a mate today he says stick to mahle and get valve cut outs machined.
Help
Help
As said MAHLE will handle that power with ease, and what I use, just get machined for cut outs, if you want to use different cams now or later, std cams are perfect for that power level as is the std turbo.
I use B.E. Randal, of Hepworth near Diss, he charges a straight 1 hour labour fee for cutting the pockets in, which is either £40 or £45, some charge £9 per cut, x 16 cuts = £144, so bit of a saving, I've just rebuilt my engine and used std with pockets for any later cam change, going later on to use a turbonetics turbo, and want a BD14, which I will get brian(randal) to do by reprofiling a std cam, if enough base circle on them.
Their number is 01359 251888.
Zee Germans are coming
i would use the 4x4 pistons as they have an off set gudgoen pin and this redused the notorious 2wd piston slap on start up when cold
and what tabetha sais also
"kiss" or "witness" marks are VERY common even with the std cams, but so slight they don't bend valves, personally I'd go Mahle, they were oe fit, and oe stuff tends to be very good generally.
The reference to the offset wrist pin, is misleading all 2wd pistons were offset as well, just not as much, currently supplied pistons will all have the same offset as 4wd, very good price from Matt Lewis, 01922 692424.
It was Matt who recomended the wisco pistons think i will wait untill Classic ford and see what he can do the best deal on.
Well spotted i think std size is 90.83mm and the wisco are 91mm or 92mm, guessing i need to get the bores checked to see if 91mm will take out the lip.
The lip is NOT the wear point, this occurs worst about halfway down the cylinder, it also makes the bore slightly oval, go along to someone like randals, and they will stick a bore gauge down there for you, I can 100% assure you they will tell you the honest truth even if it does them out of work, they have way more than enough to keep them happy.
They also bore correctly with a deck plate, if done without as some tuners do the block is not much better than scrap.
Mine was revving to 7300rpm, and clipped the pistons, if you have any amount of miles on the engine, ie 50,000+ then I'm not at all surprised that white spirit leaked out, I've seen people ruin new seats by lapping them just after they've been recut on a SERDI valve cutter, not needed and makes them worse hand lapping, it's very old hat with modern machines like the ace serdi seat cutter, at the mileage of 50,000+ the head is likely in need of new exhaust valves and all 16 guides as well as seats anyway, the guide wear is astronomical on the cossie engine, I had mine done with COLSHIBO guides, last time they'll ever need changing, all done at randals.
deathrider666
28-09-2015 06:12 PM
timsrs
22
24-09-2015 08:14 PM
