Show us your gauges
Show us your gauges
As the search function no longer has any use at all (I did try looking)
I have not see a gauge post for a while anyway so lets see your set ups and what you have as not sure what is best to display so looking for inspiration
Charlie, don't you find the light so close to your eye level a major distraction at night ?, I disconnected the light in my pillar boost gauge for that reason, unless you don't do a lot of night driving.
James90rs
Mine is similar to yours, display in centre with 2 gauges in the corners but I found the 2 gauges hard to read as the steering wheel gets in the way so am changing the gauges to less important ones
This is mine
I am tempted to fit the R&B temp gauge like you have at the bottom though as I have some spare room
This is mine
This is the thing, I have not used my car in ages and not really looked into what folks display so not sure whats important to have.
The digital dash reads from the ecu so on that I had displayed:
voltage, water temp, charge temp and throttle angle as well as the usual rpm, speed and milage.
I have a boost gauge and AFR gauge but was thinking Oil pressure, Fuel pressure and maybe one more..
Gav, fair point mate, will see what it's like when it's in
I went for it as it displays so much, with warnings for all.
Milage and trip, battery voltage, fuel level, fuel pressure, coolant temp, oil temp, oil pressure - think that's it lol.
To me, most important are oil pressure, EGT and AFR.
I'll only need one external gauge - boost!
Steve - that's from where the last engine was stopped
In place of the bulb/door warning bit area I have three gauges, volt, oil temp, oil pressure, then a combined plenum and air filter temp(switchable, cost around £5), as well as my rev limit buzzer, and a few switches, warning led's, I used electro luminescent gauges as very easy on the eye at night.
cossie fan (unluckerly)
i like the simple look heres mine vdo boost oil temp and pressure i went vdo as i needed a 3 bar boost gauge and a stack afr one the green led is for when the water injection is actived via the ecu
