3door sierra door strips
Old 04-08-2008, 11:58 AM
g10ens
g10ens's Avatar
Default 3door sierra door strips
Does anyone know of anywhere i can get hold of a set of the bump strips which fit to the exterior of the 3door doors and wings, ive tried ebay with no luck and cant think where else to try. Thanks
Old 04-08-2008, 12:26 PM
BRAMMER
BRAMMER's Avatar
£199.95 all in.
Theirs normally a 2-3 week wait but they had a few sets on site.
The lady you need to speak to is sue.colbourn@ami-models.co.uk
A.M.I. Modelmakers
Unit 8 Harvington Park
Westfield Road
Pitstone
Nr. Tring
LU7 9GU
England
T : + 44 (0) 1296 663277
F : + 44 (0) 1296 663278
M: + 44 (0) 7836 285538
E : nick.phelps@ami-models.co.uk
Old 04-08-2008, 12:28 PM
Dearo
Dearo's Avatar
This may help, not too sure on price though???
A.M.I. Modelmakers
Westfield Road
Pitstone
Nr. Tring
LU7 9GU
England
Old 04-08-2008, 12:32 PM
Dearo
Dearo's Avatar
Brammer, you beat me to it !!
Are they good quality items???
Old 04-08-2008, 04:33 PM
BRAMMER
BRAMMER's Avatar
Yes but make sure you don't pull them when fitting as they are rubber and stratch, i know i had 5mm extra over hanging the end of the door, and the double sided tape isn't the stuff that comes off easy.
Old 05-08-2008, 11:43 AM
g10ens
g10ens's Avatar
Thanks guys, i knew someone on here would be able to help!
Does this company also supply fitting instructions with the strips? A mate of mine bought some a few years ago and they came with instructions giving you the exact measurements of where to stick them and he ended up with a perfect fit.
Only trouble is he cant remember the name of the company but he did say it had 3 initials in it - so AMI sounds like it could be the one.
Old 05-08-2008, 12:11 PM
BRAMMER
BRAMMER's Avatar
Yes they come with instructions
Old 06-08-2008, 10:02 PM
AndyPen
AndyPen's Avatar
...but there is a bit of a knack to keeping them straight as there is no alloy backing like on the originals... I did using a long ruler to rest on - came out great
Old 06-08-2008, 11:14 PM
BRAMMER
BRAMMER's Avatar
Good tip Andy
Old 07-08-2008, 01:18 PM
AndyPen
AndyPen's Avatar
Here's a pic or two of how I did it mate First run a line of tape at the distance described in the instructions - from memory 32mm up from the door line but check.
Start with the door as its the longest length. Tape the ruler at the bottom and align the strip on top by resting on it...
Then slide the ruler back and front to ensure alignment is the same...
This is how it works out - I used a meter long ruler here to achieve this
Old 09-08-2008, 10:25 PM
g10ens
g10ens's Avatar
Thanks everybody, the strips are on order, should have them in about two weeks.
Old 22-08-2008, 10:09 PM
g10ens
g10ens's Avatar
They have arrived today, perfect match to the original items!
gavt123
05-09-2015 10:03 AM
hopper350
04-09-2015 12:53 AM
Vincereese
02-09-2015 07:28 PM
3doorcozmess
31-08-2015 05:15 PM
Quick Reply: 3door sierra door strips
