Throttle position sensor on saff cossie 4x4
Old 11-05-2008, 03:26 PM
Default Throttle position sensor on saff cossie 4x4
How easy are these to change and do you have to take the throttle body off to get to the sensor. Ive got a daft fault on my car when im driving it the car will chug every now and then. Sometimes when im driving it the car just goes on its own when i take my foot of the throttle pedal. It feels as if the choke has come on and the it goes back to normal. Im thinkin that it could be a faulty throttle switch.
Old 11-05-2008, 06:04 PM
oldford
oldford's Avatar
Same problem can happen if the ECT-sensor fails (a little).
Had the same problem with my own 4x4, idle was raised to 1200-1300 rpm.
Old 11-05-2008, 06:27 PM
BigErn
BigErn's Avatar
Do a sensor check with a multimeter mate, might reveal something amiss.
Old 11-05-2008, 06:43 PM
BigErn
BigErn's Avatar
crank sen, ecu pins 3&4, 600-1000 ohms
phase sen, pins 5&23, 700-1200 ohms
charge sen, pins 11&31, @10c=6000 ohms @ 20c=3750 ohms @ 30c 1600 ohms
temp sen, pins 11&29, @10c=6000 ohms @ 20c=3750 ohms @ 40c 1600 ohms @ 60c=750 ohms @ 80c=380 ohms
map sen, pins 11&30, 50-600 ohms & pins 15&30, 500-6000 ohms
Old 11-05-2008, 07:28 PM
I wouldn't like to change one is situ, a lot easier if you take it off.
Old 15-05-2008, 08:41 PM
Does the connector on the engine ecu have numbers on so i know which wires to prope.
Old 15-05-2008, 08:45 PM
BigErn
BigErn's Avatar
iirc the ecu plug has numbers on, you might have to take the small screw and cable tie off the plug cover on the harness to see them.
Old 16-05-2008, 10:11 AM
silky16v
Get on That!
silky16v's Avatar
very easy to change in situ just use a 1/4 small ratchet with screwdriver attachments
Old 17-05-2008, 10:32 PM
it must be something silly cause the past 3 to 4 days the car has driven spot on,
Cosnada
27-08-2015 09:15 AM
JoeyBoyden
20
22-08-2015 03:23 PM
Anutternutter
21-08-2015 06:07 PM
Bailes1992
16-08-2015 07:14 PM
Zoggon
10-08-2015 10:39 AM
Quick Reply: Throttle position sensor on saff cossie 4x4
