back firing at high revs
im new to cossies so help me out
my 2wd saph backfires & splutters at high revs so whats the crack there as its hampering its performance a bit & the boost is peeking at around 14psi
it has green injectors, bajoo chip, rs 500 intercooler, collins actuater, 3 bar map sensor, k&n & stainless exhaust & maybe a hybrid turbo but im not sure, has dyno graphs for 340bhp
im thinking maybe a set up as it sat for nearly 8 months plus, i havent changed the plugs & leads yet either
cheers
cheers
Good advice, just change the usuall suspects, ie plugs, make sure it has decent leads, inspect the insulation on the phase sensor, change the CTS, get it set up for peace of mind.
Do the FUEL FILTER as well, although this small item will not give the misfire, it is so often neglected, but is so easy to do, ok then it can be a royal pain in the rear with brackets breaking etc but is important!!
I would set it very low, and take it to a rolling road for a fuelling check etc where they can adjust it to what chip supplier says is correct for the chip.
On this power usually around 24/26psi.
ok ive been a bit busy today but popped in to halfrauds to get plugs, leads & oil but they dont sell the plugs & leads so where would you recomend i get them & what kind??
cheers
cheers
ekjim
17-08-2015 08:57 PM
