my new exhaust
my new exhaust
What do you think about it? 76mm inside tube, 80mm outer, stainless steel; + Custom muffler
http://photofile.com.ua/users/87255/...8/?mode=xlarge
After I install it + install 2wd exh. manifold my AFR increase from 11.5-11.7(when was 60mm tube + 4wd manifold) to 12.4-12.3(2wd + 80mm) at full boost.
no, It has more low sound then before, because this mufler has construction like mufler HKS Super Drag - inlet D=76mm, but inside mufler at the end(out) side it has a tube with small lenght(about 100mm) and D=63mm. So outer D=63. At idle speed and little throttle sound is low. But at full boost it loud and sound is very dangerous.
