cps gap?
Old 12-04-2008, 10:26 PM
mechanic28
mechanic28's Avatar
Default cps gap?
as above what is the correct gap to set the cps to the aux pulley?seem to remember 0.2 too 0.3mm?
cheers
dougie
Old 13-04-2008, 08:47 AM
MARCOSWORTH
MARCOSWORTH's Avatar
You mean engine speed/TDC sensor?
This should be 0,6 - 1,0mm
Old 13-04-2008, 08:57 AM
As said(CPS) 0.6mm to 1.0mm, though they will work from 0.1mm to about 3.5mm!!
Make sure you check the gap on ALL lugs as if you set it on a low one then a high one could come round and clout the sensor, as the lugs get a bit worn/corroded due to age impact.
The phase sensor as said is 0.2mm to 0.3mm but again will work wildly outside of this but obvioulsy the signal gets abit dirty.
DixieTheKid
11
06-06-2020 11:20 AM
01-11-2015 06:53 PM
Chas
05-10-2015 07:13 PM
biggiejody
19-09-2015 10:25 AM
wheelwizardrefurbs
18-09-2015 08:59 PM
Quick Reply: cps gap?
