Bilstein 909 Coilovers
Old 17-03-2008, 08:46 PM
steve87
steve87's Avatar
Default Bilstein 909 Coilovers
HI
I've just baught a set of 909 Bilstiens coilovers to fit to my 2wd sapph they have just been refurbed and didn't come with springs,
The trouble is that I don't know spring length I need to fit. Reyland said they can supply the springs for £20 each but need to know the length,
does anyone know what length I need or how I can find out?
Thankyou, Steve.
Old 17-03-2008, 09:00 PM
STUCOS
STUCOS's Avatar
Steve what you using car for
cheeRS stu
Old 17-03-2008, 09:58 PM
steve87
steve87's Avatar
Cheers for your response mate,
I am using the car for road use and track use aswell.
Id like the setup to be as stiff as possible but that I can still use on the road,
Its, not a daily driver.
or would these only really suit a full time track car?
Old 17-03-2008, 10:21 PM
BRIGSPORT
UNAUTHORISED DEVELOPMENTS
BRIGSPORT's Avatar
I'm in the same boat mate,any info much appreciated. Mine is a 2wd v6 sierra though.
Old 18-03-2008, 08:08 AM
I use on my AVO, front 300lb 9" long, rear 200lb 12" long
Old 18-03-2008, 09:16 AM
STUCOS
STUCOS's Avatar
Hi steve,have the same set up on my 3dr,running 300ilb x 10" springs front and 180ilb x 12" on rear, did have 220 on rear and 400 front but far to hard,are your 909 tarmac or gravel spec
cheeRS stu
Old 18-03-2008, 08:17 PM
steve87
steve87's Avatar
Would AVO be the same as the bilstiens set up then Tabetha? I mean if the springs are the same length on an AVO would they give the same affect as on the BIlstiens.
Old 18-03-2008, 08:23 PM
steve87
steve87's Avatar
STUCOS Im Hoping there tarmac springs, I have been told this Although I'm not certain myself, I dont know how I'd tell.
How do you like your setup now?
If you dont mind me asking, what do you use the car for just track or road?
Old 19-03-2008, 07:05 AM
Different dampers(make) will have different spring rates, but get it how YOU want it, as the supplied ones may not be what you like and this is the point of suspension, to adjust to suit you.
Old 19-03-2008, 07:08 PM
STUCOS
STUCOS's Avatar
Steve you got a contact number,will give you a bell,and talk about your spec
cheeRS stu
Old 20-03-2008, 09:46 PM
steve87
steve87's Avatar
Thanks for The advice Tabetha,
I think every time I have posted a question on here you've managed to help me someway!!
Im going to speak to Stu as he has very kindly offered to go through the spec of my car with me over the phone.
Thanks again mate
Old 20-03-2008, 10:39 PM
STUCOS
STUCOS's Avatar
Steve give you a bell tomorrow
cheeRS stu
Old 20-03-2008, 10:42 PM
Micky The Finn
Former Sponsor
Micky The Finn's Avatar
Originally Posted by steve87
HI
Thankyou, Steve.
what are you using them for?tarmac or gravel?
Old 21-03-2008, 08:51 PM
steve87
steve87's Avatar
Im using them on tarmac mate but also on the road.
Old 24-03-2008, 07:33 PM
steve87
steve87's Avatar
Ive gone for 300lb front springs and 225lb on the rear thanks to Stu. Talked through it with him on the phone, and he managed to sort me out a set as well. cheers mate!
mk1turboestate
02-12-2015 08:31 PM
S3an
26-09-2015 11:39 PM
IainRS1700T
25-09-2015 06:44 AM
CrOwSoN15
24-09-2015 01:36 PM
truffleshuffle
10-09-2015 09:35 PM
Quick Reply: Bilstein 909 Coilovers
