what plugs for cossie?
Old 14-03-2008, 12:54 PM
Zetec_mk4_XR3i
Zetec_mk4_XR3i's Avatar
Default what plugs for cossie?
when i give my 4x4 cossie a good bit of right foot, it cuts out and my mate who is good with them thinks its blowing the spark out when its on boost - its just running NGK plugs from Halfords which were the ones the computer came up with when the reg was entered - any suggestions which plugs to go for? Its stage 1 with a green top engine if that helps
Old 14-03-2008, 03:23 PM
071's area good plug that suits most tunes, but for stage 1 you could use AGPR12PP8, these are precious metal ones, so about £40, but with a group a coil work wonders.
You can get these bits from Matt Lewis 01922 692424, and you WILL notice a smoother idle and better low down with the plugs/coil.
It could be blowing the spark out but does NOT cause cut outs normally, just a wall of no extra boost, just revs as does not create enough exhaust gas to spin turbo very fast, as intermittantly misfiring, all you will feel is no power, no real roughness.
Use a 0.65mm gap as this works well, also make sure you have decent leads, like Magnecor etc.
Old 14-03-2008, 03:53 PM
Zetec_mk4_XR3i
thanks so much
Old 14-03-2008, 04:23 PM
KSA-Cossie
KSA-Cossie's Avatar
071's job done m8.
Old 14-03-2008, 04:39 PM
Zetec_mk4_XR3i
thats what i got mate but car didnt seem happy with them - think need to check the gaps on them though
put in the old ngks and it ran lovely but blew spark out on boost
Old 14-03-2008, 04:53 PM
KSA-Cossie
KSA-Cossie's Avatar
gap them at 0.8mm my saph runs great on them.
Old 14-03-2008, 06:51 PM
col cos1
col cos1's Avatar
myself and euan both run ngk bcr8es plugs on big specced cars with no issues and cost around £10 for four
i tried hks iridium plugs at £60 a set and they were shite kept misfiring at 7200rpm
Old 14-03-2008, 06:52 PM
KSA-Cossie
KSA-Cossie's Avatar
I ran them in both my erst's,good plugs.
Old 15-03-2008, 09:59 AM
Zetec_mk4_XR3i
cheers guys - will get a set of them today to try
sorry...last question do those ngks come gapped do you know or should i check em?
Old 15-03-2008, 01:21 PM
cossiegreg1
cossiegreg1's Avatar
col what you gapped these at
01-11-2015 06:53 PM
gcfcos
59
06-10-2015 05:04 PM
Brickhouse
14
03-10-2015 07:28 PM
XR4
Ford XR Range
01-10-2015 12:46 PM
deathrider666
28-09-2015 06:12 PM
Quick Reply: what plugs for cossie?
