big discs for standard calipers
Old 30-01-2008, 09:06 PM
155lee
155lee's Avatar
Default big discs for standard calipers
hi,i have a 2wd cos,i want bigger discs and brackets for the fron,where do you get them and how much?cheers,lee
Old 30-01-2008, 09:10 PM
SteveB
SteveB's Avatar
Hi Spec
Old 31-01-2008, 04:34 AM
stevecossy
stevecossy's Avatar
hi Esp design sell the hi spec kits, bigger discs and relocation brackets with std calipers.
Old 31-01-2008, 10:03 AM
wildheart
wildheart's Avatar
email mike rainbird and he'll sort you out
Old 31-01-2008, 04:18 PM
Contact reyland or Zoo as they do brackets to suit FRS front discs, which are 324mm, cheapest way of doing it, they also supply the wider spacer needed to put between your caliper halves to suit wider disc which is 32mm ,and not 24mm.
Old 31-01-2008, 04:33 PM
SteveB
SteveB's Avatar
FRS discs are 28mm wide and as Tabetha says good cheap conversion (I didn't know anyone didi it yet)...
Old 31-01-2008, 06:20 PM
SteveB is quite correct they are 28mm wide, sorry getting a bit mixed up here.
Old 31-01-2008, 09:11 PM
155lee
155lee's Avatar
yeah,phoned hi spec today and they qouted Ł418 plus vat for the 325mm kit which i thought was a bit steep.how much do the frs discs and brackets cost?
Old 31-01-2008, 09:35 PM
SteveB
SteveB's Avatar
Go to someone who sells Brembo discs ( http://www.gsfcarparts.com/ do them and do mail order) and ask for pt no. 09.5486.50 that is the Brembo part number for FRS discs and should cost you about Ł100 + vat, a set of brackets and spacers imo should be no more than Ł120-Ł150
Old 31-01-2008, 09:39 PM
155lee
155lee's Avatar
mint,ill get on that asap.cheers for the info!
Old 31-01-2008, 09:48 PM
SteveB
SteveB's Avatar
No probs matey....
Have a look here...
https://passionford.com/forum/viewtopic.php?t=312773
That's my car with FRS discs and Brembo calipers from a Merc (I think got em from Ebay...lol). I made my own brackets from mock up to finished brackets in about 3 hrs...
Old 03-02-2008, 01:47 PM
scotty4130
scotty4130's Avatar
What size of wheels are needed to fit the FRS discs behind?
Old 03-02-2008, 03:17 PM
SteveB
SteveB's Avatar
16" if they are motorsport dervied or at least 17" (I'm on 18" and have loads of clearance)
Old 03-02-2008, 05:08 PM
AndyPen
AndyPen's Avatar
These are on my 500 and they are cracking Think I need an imperial size allan key to get the caliper off too. Anyone recognise the set up possibly?
yatta
21-05-2016 10:31 PM
DPDISXR4Ti
Ford Fiesta
21-09-2015 03:51 PM
Adam Graham
06-09-2015 06:04 AM
rsturbo27
05-09-2015 05:08 PM
cossirob
03-09-2015 09:17 PM
Quick Reply: big discs for standard calipers
