Sapphire rear bumper removal
I'm trying to remove the rear bumper on my 2wd sapphire cossie, I have found the plastic side clips but it still won't budge.
Are there any other bolts or clips that I need to remove and where abouts are they?
Ben
Ben
Location: Linlithgow and Drives a 1989 Flint Grey Sierra Cosworth
I take it you have turned the two plastic clips through 90 degrees? The ones behind the wheel arch liners on the bumper?
There are also two torx bolts that secure the bumper frame to the bottom of the floor pan. These are located under the boot carpet, one on each side infront of the rear lights.
Bruce
Bruce
Received 1,042 Likes
Yeh there are two 40 torx bits on the boot floor. I bet they are seized i had to drill mine out. I was fitting a new bumper cause my old 1 was cracked. If your fitting your bumper back on you will have to drill and retap the threads on the bumper brackets.
Bruce
Bruce
Bruce
Bruce
When the bolts are out, then slide the bumper off the rear of the car. If its abit sticky be patient and even spray some wd40 on the plastic sliders near the plastic clips you turned.
Bruce
09-10-2015 07:38 PM
borboyous
22-08-2015 11:17 AM
track.focus'd
12-08-2015 05:53 PM
