AFR
Originally Posted by miller3
Tev
Thanks mate' That's what im just sorting out
Yes but i think you have to buy the Thermocouple sensor separately for the EGT
http://shop.vems.hu/catalog/product_...roducts_id=101
All the connectors to make it work (WBO2 connector, supply, fuse)
Looks the part n is cheap enough
This is a good gauge
http://cgi.ebay.co.uk/Innovate-Motor...QQcmdZViewItem
i use my innovate LC1 set.
it has 2 analoge out- 1 for the gauge and 1 for the ecu.
you can programm how you like it.
i programmed 1 out to 0,5volt@ lambda 0,5
and 1,5volt@lambda 1,5
so i can use a cheap voltmeter.
with the 2nd you can play and set your lambda settings how you like.
you can disconnect your stock one.
cost ~150pounds.
cost ~150pounds.
wheelwizardrefurbs
22-09-2015 05:45 PM
Fiecos Dan
57
22-10-2006 09:18 PM
